kangming created an issue |
Unable crop coverage witch is result of gs:BarnersSurface with WPS chain in sld |
Issue Type: |
Affects Versions: |
2.7.0 |
Assignee: |
Unassigned |
Attachments: |
sld.xml |
Created: |
04/Jan/16 11:43 AM |
Environment: |
Geoserver 2.7 PostGIS 2.1.7 |
Labels: |
SLD geoserver |
Priority: |
Reporter: |
I would like to perform a gs:CropCoverage of the Raster Layer which is the result of gs:BarnesSurface. But when it’s throw a error. Error info is below:
04 一月 09:41:46 DEBUG [geotools.jdbc] - CREATE CONNECTION
04 一月 09:41:46 DEBUG [geotools.filter] - exporting PropertyName
04 一月 09:41:46 DEBUG [geotools.filter] - exporting LiteralExpression
04 一月 09:41:46 DEBUG [geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
04 一月 09:41:46 DEBUG [geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
04 一月 09:41:46 DEBUG [geotools.jdbc] - SELECT “gid”,“id”,“stationcode”,“stationname”,“station_lo”,“station_la”,“citycode”,“cityname”,“provincena”,“remarks”,“weather_st”,“weather_1",“weather2","weather3”,"weather4",“distance”,“area”,“id_d1”,“id_d2”,“id_d3”,“地域”,encode(ST_AsEWKB(“geom”),‘base64’) as “geom”,“code”,“o3_8h” FROM (select s.*,p.o3_8h from station s left join t_sc_pollutant_v0020_hour p on p.stationcode=s.code where p.monitordate= to_timestamp(‘2015-10-19 16:00:00’,‘YYYY-MM-DD HH24:MI:SS’)
) as “vtable” WHERE “geom” && ST_GeomFromText(‘POLYGON ((-∞ -∞, -∞ ∞, ∞ ∞, ∞ -∞, -∞ -∞))’, 3857)
04 一月 09:41:46 ERROR [geotools.jdbc] - Failed to execute statement SELECT “gid”,“id”,“stationcode”,“stationname”,“station_lo”,“station_la”,“citycode”,“cityname”,“provincena”,“remarks”,“weather_st”,"weather1",“weather2","weather3”,"weather_4”,“distance”,“area”,“id_d1”,“id_d2”,“id_d3”,“地域”,encode(ST_AsEWKB(“geom”),‘base64’) as “geom”,“code”,“o3_8h” FROM (select s.*,p.o3_8h from station s left join t_sc_pollutant_v0020_hour p on p.stationcode=s.code where p.monitordate= to_timestamp(‘2015-10-19 16:00:00’,‘YYYY-MM-DD HH24:MI:SS’)
04 一月 09:41:46 DEBUG [geotools.jdbc] - CLOSE CONNECTION
04 一月 09:41:46 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:344)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:259)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:132)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:504)
at org.geoserver.wms.GetMap.run(GetMap.java:248)
at org.geoserver.wms.GetMap.run(GetMap.java:119)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:320)
at sun.reflect.GeneratedMethodAccessor196.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:62)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:36)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:80)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy66.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor153.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:845)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:275)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:654)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1320)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1291)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:83)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:443)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:532)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:227)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1044)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:372)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:189)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:978)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:255)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:154)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:369)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:486)
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:933)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:995)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:644)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:668)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:52)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
at java.lang.Thread.run(Unknown Source)
Caused by: org.geoserver.platform.ServiceException: java.lang.RuntimeException: Failed to evaluate the process function, error is: java.lang.RuntimeException: java.io.IOException
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:1055)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:342)
… 114 more
Caused by: java.lang.RuntimeException: Failed to evaluate the process function, error is: java.lang.RuntimeException: java.io.IOException
at org.geotools.process.function.ProcessFunction.evaluate(ProcessFunction.java:155)
at org.geotools.process.function.ParameterFunction.evaluate(ParameterFunction.java:104)
at org.geotools.process.function.ParameterFunction.evaluate(ParameterFunction.java:120)
at org.geotools.process.function.ProcessFunction.evaluateInputs(ProcessFunction.java:174)
at org.geotools.process.function.ProcessFunction.evaluate(ProcessFunction.java:137)
at org.geotools.renderer.lite.RenderingTransformationHelper.applyRenderingTransformation(RenderingTransformationHelper.java:216)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:1008)
… 115 more
Caused by: org.geotools.process.ProcessException: java.lang.RuntimeException: java.io.IOException
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:565)
at org.geotools.process.function.ProcessFunction.evaluate(ProcessFunction.java:142)
… 121 more
Caused by: java.lang.RuntimeException: java.io.IOException
at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:176)
at org.geotools.process.vector.BarnesSurfaceProcess.extractPoints(BarnesSurfaceProcess.java:388)
at org.geotools.process.vector.BarnesSurfaceProcess.execute(BarnesSurfaceProcess.java:226)
at sun.reflect.GeneratedMethodAccessor205.invoke(Unknown Source)
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:549)
… 122 more
Caused by: java.io.IOException
at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:649)
at org.geotools.data.store.ContentFeatureSource.getReader(ContentFeatureSource.java:634)
at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:173)
… 128 more
Caused by: java.sql.SQLException: org.postgresql.util.PSQLException: ERROR: parse error - invalid geometry
建议:“POLYGON ((?” <- parse error at position 12 within geometry
at org.geotools.jdbc.JDBCFeatureReader.(JDBCFeatureReader.java:155)
at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:619)
… 130 more
Caused by: org.postgresql.util.PSQLException: ERROR: parse error - invalid geometry
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2270)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1998)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:255)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:570)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:406)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:286)
at org.apache.commons.dbcp.DelegatingStatement.executeQuery(DelegatingStatement.java:208)
at org.geotools.jdbc.JDBCFeatureReader.(JDBCFeatureReader.java:146)
… 131 more
This message was sent by Atlassian JIRA (v7.1.0-OD-03-048#71001-sha1:1116670) |
