Hello.
We import osm.pbf Europe to postgresql and we try to display it in WMS in geoserver. All layers without polygons works well. No matter what style you set, at no you do not see.
On version 2.4.4 works well, but higher (2.5.5.1, 2.6.2, 2.7.5, 2.81. 2.8.2) not.
here is error from console:
Caused by: java.lang.IllegalArgumentException: class com.vividsolutions.jts.geom.Geometry is not supported by this method
at org.geotools.data.DataUtilities.defaultValue(DataUtilities.java:1015)
at org.geotools.feature.simple.SimpleFeatureBuilder.convert(SimpleFeatureBuilder.java:323)
at org.geotools.feature.simple.SimpleFeatureBuilder.set(SimpleFeatureBuilder.java:310)
at org.geotools.feature.simple.SimpleFeatureBuilder.add(SimpleFeatureBuilder.java:233)
at org.geotools.jdbc.JDBCFeatureReader.next(JDBCFeatureReader.java:378)
at org.geotools.jdbc.JDBCFeatureReader.next(JDBCFeatureReader.java:75)
at org.geotools.data.store.ContentFeatureCollection$WrappingFeatureIterator.next(ContentFeatureCollection.java:153)
at org.geotools.data.store.ContentFeatureCollection$WrappingFeatureIterator.next(ContentFeatureCollection.java:133)
at org.geotools.renderer.lite.StreamingRenderer.drawPlain(StreamingRenderer.java:2283)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1905)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:821)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:539)
… 106 more
2016-02-17 04:26:24,492 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
All log: http://wklej.org/id/1961793/
Would you be able to fix it? Thank you in advance.
