Andrea Aime [Administrator] created an issue |
Improper use of TemporaryFolder leaves test folders in $java.io.tmpdir |
Issue Type: |
Assignee: |
Unassigned |
Created: |
27/Mar/16 12:06 PM |
Priority: |
Reporter: |
TemporaryFolder must be used as a @Rule in order for the folders to be deleted at the end of the run, our code base just instantiates as a local variable instead |
This message was sent by Atlassian JIRA (v7.2.0-OD-04-029#72002-sha1:f50e4de) |
