Andreas W created an issue |
Issue Type: |
Affects Versions: |
2.8.2 |
Assignee: |
Unassigned |
Components: |
Main |
Created: |
29/Mar/16 12:46 PM |
Priority: |
Reporter: |
When creating layers based on SQL Views it is possible to set geometry type and srid for each geometry column manually. These settings are saved in the corresponding GeoServer XML configuration. However, when reading the configuration, GeoServer currently only considers the type and srid for last geometry column. The others are ignored. Instead the settings for all columns should be considered. |
This message was sent by Atlassian JIRA (v7.2.0-OD-04-029#72002-sha1:f50e4de) |
