[Geoserver-devel] [JIRA] (GEOS-7514) LDAP AuthenticationProvider attempts to use non-ldap login to fetch groups from ldap server
Niels Charlier created an issue
GeoServer / BugGEOS-7514
Issue Type:
BugBug
Affects Versions:
2.9-beta
Assignee:
Niels Charlier
Components:
Security
Created:
21/Apr/16 12:14 PM
Fix Versions:
2.9-beta2
Priority:
HighHigh
Reporter:
Niels Charlier
When you configure the LDAP Authentication Provider to NOT bind before searching groups,rather than searching anonymously it will attempt to use your geoserver non-LDAP login to connect to LDAP, causing an exception.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.2.0-OD-05-030#72002-sha1:7e8526a)
Atlassian logo
