David Blasby created an issue |
VectorTiles: MVP external library is doing improper clipping. |
Issue Type: |
Affects Versions: |
2.9-beta2, 2.8.3 |
Assignee: |
Unassigned |
Components: |
Community modules |
Created: |
27/Apr/16 11:24 PM |
Environment: |
all |
Priority: |
Reporter: |
Vector Tiles uses external module https://github.com/ElectronicChartCentre/java-vector-tile This module does some clipping; NOTE: the geoserver VT module already does the needed clipping so this module is re-clipping already clipped geometries Also see discussion in; They just released 1.0.9 which makes it easy to sub-class and change the clipping behavior. |
This message was sent by Atlassian JIRA (v1000.5.0#72002-sha1:17539a9) |
