[Geoserver-devel] [JIRA] (GEOS-7543) REST Putting a WFS Settings xml results into an Unauthorized class found during XStream conversion
Daniele Romagnoli created an issue
GeoServer / BugGEOS-7543
Issue Type:
BugBug
Affects Versions:
2.9-RC1, 2.8.3
Assignee:
Unassigned
PUTException.log
Components:
REST, WFS
Created:
18/May/16 11:42 AM
Priority:
MediumMedium
Reporter:
Daniele Romagnoli
The XStreamPersister initializers and loaders declare the allowed types for XML Unmarshalling.
The WFSXStreamLoader declares WFSInfo.Version.class and GMLInfoImpl.class as allowedTypes.
https://github.com/geoserver/geoserver/blob/master/src/wfs/src/main/java/org/geoserver/wfs/WFSXStreamLoader.java#L33
However, trying to put a wfs settings.xml result into the attached PUTException.log.
Steps to replicate it:
Simply send a PUT request against:
http://HOST:PORT/geoserver/rest/services/wfs/settings.xml
using the wfs.xml settings available on the “release” data dir available in the /data dir of the geoserver code as body of the PUT.
https://github.com/geoserver/geoserver/blob/master/data/release/wfs.xml
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.5.2#72002-sha1:b4422fe)
Atlassian logo
