[Geoserver-devel] [JIRA] (GEOS-7610) Problem with style for wind direction data
Matteo Rivola created an issue
GeoServer / BugGEOS-7610
Issue Type:
BugBug
Affects Versions:
2.8.4
Assignee:
Unassigned
error.txt, wind_style_1.xml, wind_style_2.xml
Components:
WMS, WPS
Created:
30/Jun/16 11:34 AM
Environment:
OS Ubuntu 15.10
JVM version 1.7.0_80 (Java HotSpot™ 64-Bit Server VM)
Postgresql server version 9.4
JNDI connection pool
Priority:
MediumMedium
Reporter:
Matteo Rivola
I have published one band raster data representing wind direction like Image Mosaics.
They are in EPSG:4258 with a BBOX [-16.058210564139415,32.96955965348397,39.2896078071642,80.02803653793978]
I create a style that represents the wind direction with arrows, in function of the pixel values (see attached file wind_style_1.xml).
When i call the layer with this WMS
“127.0.0.1/geoserver/wind/wms?port=8181&LAYERS=id1359s011011r000-europe&TRANSPARENT=TRUE&VERSION=1.1.0&TIME=2016-04-29T10%3A06%3A00.000Z&TILED=true&SERVICE=WMS&REQUEST=GetMap&STYLES=&FORMAT=image%2Fpng&SRS=EPSG%3A4258&BBOX=29,33,74,78&WIDTH=256&HEIGHT=256”
I expect to get an empty image for that BBOX and for that TIME, but I get an unexpected exception (see the full stack trace in “error.txt” file in attach).
I replaced in the first style “TextSymbolizer” with “PointSymbolizer” like in wind_style_2.xml but the issue still remain.
The problem happen only for the styles linked. If I use a style with the RULE “RasterSymbolizer” I have no exception for the same layer.
If I publish the same raster with the same style In a geoserver version 2.7.1 that I use for other projects it works properly (this geoserver is running with 1.7.0_65 (OpenJDK 64-Bit Server VM) and Postgresql server version 9.2).
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.110.0#100004-sha1:4011b0e)
Atlassian logo
