I’ve been having some real trouble upgrading from 2.6.x to 2.8.x
I think in part this is because the data directory contents have slightly changed due to the addition of the blobstore attributes but I’m at a bit of a loss now.
The error stack is giving me nothing to go on now but can anyone see an error cause in the stack trace?
2016-07-04 12:55:49,834 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
2016-07-04 12:55:49,834 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
2016-07-04 12:55:49,834 INFO [diskquota.DiskQuotaMonitor] - 1031 layers attached to global quota 500.0 MB
2016-07-04 12:55:51,069 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 10 SECONDS
2016-07-04 12:55:52,491 INFO [org.geoserver] - Loaded service ‘wcs’, enabled
2016-07-04 12:55:52,506 INFO [org.geoserver] - Loaded service ‘wfs’, enabled
2016-07-04 12:55:52,522 INFO [org.geoserver] - Loaded service ‘wms’, enabled
2016-07-04 12:55:52,538 INFO [org.geoserver] - Loaded service ‘WPSInfoImpl–46ae71cc:155b4f274e0:-7ff4’, enabled
2016-07-04 12:55:52,678 INFO [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
2016-07-04 12:55:52,694 INFO [geoserver.monitor] - Monitor hibernate extension enabled
2016-07-04 12:55:53,069 INFO [ows.OWSHandlerMapping] - Mapped URL path [/gwc/service/] onto handler ‘dispatcher’
2016-07-04 12:55:53,131 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
2016-07-04 12:55:53,710 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 15 paths
2016-07-04 12:55:53,819 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
2016-07-04 12:55:53,819 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
2016-07-04 12:55:53,928 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller in a background job…
2016-07-04 12:55:55,741 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml] onto handler ‘dispatcher’
2016-07-04 12:55:55,741 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml/*] onto handler ‘dispatcher’
2016-07-04 12:55:55,741 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml/icon//] onto handler ‘kmlIconService’
2016-07-04 12:55:55,975 WARN [turbojpeg.TurboJPEGMapResponse] - The turbo jpeg encoder is available for usage
2016-07-04 12:55:55,975 WARN [turbojpeg.TurboJPEGMapResponse] - The turbo jpeg encoder has been explicitly disabled
2016-07-04 12:55:56,006 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found, poller will not run.
2016-07-04 12:55:56,085 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows/] onto handler ‘dispatcher’
2016-07-04 12:55:56,085 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler ‘dispatcher’
2016-07-04 12:55:56,116 INFO [org.geoserver] - GeoServer configuration lock is enabled
2016-07-04 12:55:56,163 INFO [geoserver.monitor] - Monitor extension enabled
2016-07-04 12:55:57,553 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler ‘dispatcher’
2016-07-04 12:55:57,553 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/] onto handler ‘dispatcher’
2016-07-04 12:56:00,116 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs/] onto handler ‘dispatcher’
2016-07-04 12:56:00,116 INFO [ows.OWSHandlerMapping] - Mapped URL path [/TestWfsPost] onto handler ‘wfsTestServlet’
2016-07-04 12:56:00,116 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs] onto handler ‘dispatcher’
2016-07-04 12:56:07,007 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms/] onto handler ‘dispatcher’
2016-07-04 12:56:07,007 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms] onto handler ‘dispatcher’
2016-07-04 12:56:07,257 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate] onto handler ‘dispatcher’
2016-07-04 12:56:07,257 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate/] onto handler ‘dispatcher’
2016-07-04 12:56:08,491 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wps] onto handler ‘dispatcher’
2016-07-04 12:56:08,491 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wps/*] onto handler ‘dispatcher’
2016-07-04 12:56:08,725 INFO [ows.OWSHandlerMapping] - Mapped URL path [/temp/**] onto handler ‘filePublisher’
2016-07-04 12:56:09,350 INFO [geoserver.wps] - Blacklisting process ras:RasterZonalStatistics2 as the input zones of type class java.lang.Object cannot be handled
2016-07-04 12:56:09,350 INFO [geoserver.wps] - Blacklisting process ras:RasterZonalStatistics2 as the input nodata of type class it.geosolutions.jaiext.range.Range cannot be handled
2016-07-04 12:56:09,366 INFO [geoserver.wps] - Blacklisting process ras:RasterZonalStatistics2 as the input rangeData of type class java.lang.Object cannot be handled
2016-07-04 12:56:09,366 INFO [geoserver.wps] - Blacklisting process ras:RasterZonalStatistics2 as the output zonal statistics of type interface java.util.List cannot be handled
2016-07-04 12:56:09,366 INFO [geoserver.wps] - Found 14 bindable processes in Raster processes
2016-07-04 12:56:09,366 INFO [geoserver.wps] - Found 5 bindable processes in GeoServer specific processes
2016-07-04 12:56:09,397 INFO [geoserver.wps] - Found 29 bindable processes in Vector processes
2016-07-04 12:56:10,054 INFO [geoserver.wps] - Found 89 bindable processes in Deprecated processes
2016-07-04 12:56:10,069 INFO [geoserver.wps] - Found 48 bindable processes in Geometry processes
2016-07-04 12:56:10,819 INFO [geoserver.wms] - Loaded font file D:\data_dir2\styles\MAPSYM.TTF, loaded font ‘Map Symbols’ in family ‘Map Symbols’
2016-07-04 12:56:10,819 INFO [geoserver.wms] - Loaded font file D:\data_dir2\styles\TTMIMI__.TTF, loaded font ‘MapInfo Miscellaneous’ in family ‘MapInfo Miscellaneous’
2016-07-04 12:56:11,663 INFO [geoserver.security] - Start reloading user/groups for service named default
2016-07-04 12:56:11,679 INFO [geoserver.security] - Reloading user/groups successful for service named default
2016-07-04 12:56:11,819 INFO [geoserver.security] - AuthenticationCache Initialized with 1000 Max Entries, 300 seconds idle time, 600 seconds time to live and 3 concurrency level
2016-07-04 12:56:11,819 INFO [geoserver.security] - AuthenticationCache Eviction Task created to run every 600 seconds
2016-07-04 12:56:11,944 INFO [georss.GeoRSSPoller] - destroy() invoked
2016-07-04 12:56:11,944 INFO [geowebcache.GeoWebCacheDispatcher] - GeoWebCacheDispatcher.destroy() was invoked, shutting down.
2016-07-04 12:56:11,944 INFO [diskquota.DiskQuotaMonitor] - Disk quota monitor shutting down…
2016-07-04 12:56:11,944 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota usage monitor…
2016-07-04 12:56:11,944 INFO [diskquota.QuotaUpdatesMonitor] - Shutting down quota usage monitor…
2016-07-04 12:56:11,944 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota statistics gathering monitor…
2016-07-04 12:56:11,944 INFO [diskquota.QueuedQuotaUpdatesConsumer] - Shutting down quota update background task due to InterruptedException
2016-07-04 12:56:12,976 INFO [diskquota.QueuedUsageStatsConsumer] - Shutting down quota update background task due to interrupted exception
2016-07-04 12:56:12,976 INFO [seed.SeederThreadPoolExecutor] - Initiating shut down for running and pending seed tasks…
2016-07-04 12:56:12,976 INFO [seed.SeederThreadPoolExecutor] - Seeder thread pool executor shut down complete.
2016-07-04 12:56:12,976 INFO [storage.DefaultStorageBroker] - Destroying StorageBroker
2016-07-04 12:56:13,007 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name ‘geoWebCacheExtensions’: Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
Any hints would be great?
Paul
