This error happens with geofence-server (but is not specific to geofence) installed and can be reproduced performing the following steps:
- Create an importer task:
Unable to find source-code formatter for language: json. Available languages are: actionscript, html, java, javascript, none, sql, xhtml, xml
"import": {
"targetWorkspace": {
"workspace": {
"name": "it.geosolutions"
curl -u admin:geoserver -XPOST -H "Content-type: application/json" -d @import.json "http://localhost:8080/geoserver/rest/imports"
- Upload the data (I zipped nyc shapefiles provided with GeoServer):
curl -u admin:geoserver -F name=nyc.zip -F filedata=@nyc.zip "http://localhost:8080/geoserver/rest/imports/0/tasks"
- Start the import task asynchronously:
curl -u admin:geoserver -XPOST "http://localhost:8080/geoserver/rest/imports/0?async=true"
We should get this exception:
java.lang.IllegalStateException: No thread-bound request found: Are you referring to request attributes outside of an actual web request, or processing a request outside of the originally receiving thread? If you are actually operating within a web request and still receive this message, your code is probably running outside of DispatcherServlet/DispatcherPortlet: In this case, use RequestContextListener or RequestContextFilter to expose the current request.
at org.springframework.web.context.request.RequestContextHolder.currentRequestAttributes(RequestContextHolder.java:131)
at org.geoserver.geofence.GeofenceAccessManager.retrieveCallerIpAddress(GeofenceAccessManager.java:253)
at org.geoserver.geofence.GeofenceAccessManager.getAccessLimits(GeofenceAccessManager.java:367)
at it.geosolutions.security.alb.AlbMultiplexingAccessManager.getAccessLimits(AlbMultiplexingAccessManager.java:122)
at org.geoserver.security.ResourceAccessManagerWrapper.getAccessLimits(ResourceAccessManagerWrapper.java:210)
at org.geoserver.security.CatalogFilterAccessManager.getAccessLimits(CatalogFilterAccessManager.java:64)
at org.geoserver.security.SecureCatalogImpl.buildWrapperPolicy(SecureCatalogImpl.java:811)
at org.geoserver.security.SecureCatalogImpl.buildWrapperPolicy(SecureCatalogImpl.java:771)
at org.geoserver.security.SecureCatalogImpl.checkAccess(SecureCatalogImpl.java:510)
at org.geoserver.security.SecureCatalogImpl.getResourceByName(SecureCatalogImpl.java:390)
at org.geoserver.catalog.impl.AbstractFilteredCatalog.getResourceByName(AbstractFilteredCatalog.java:304)
at org.geoserver.catalog.impl.AbstractCatalogDecorator.getResourceByName(AbstractCatalogDecorator.java:234)
at org.geoserver.importer.Importer.findUniqueResourceName(Importer.java:1427)
at org.geoserver.importer.Importer.addToCatalog(Importer.java:1374)
at org.geoserver.importer.Importer.doIndirectImport(Importer.java:1000)
at org.geoserver.importer.Importer.run(Importer.java:852)
at org.geoserver.importer.Importer.run(Importer.java:802)
at org.geoserver.importer.Importer$5.call(Importer.java:881)
at org.geoserver.importer.Importer$5.call(Importer.java:875)
at org.geoserver.importer.job.Job.call(Job.java:16)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
This error happens because the importer is not sharing the current request context when running a job asynchronously:
https://github.com/geoserver/geoserver/blob/master/src/extension/importer/core/src/main/java/org/geoserver/importer/Importer.java#L874-L890
