Tuure Laurinolli created an issue |
Issue Type: |
Affects Versions: |
2.9.1 |
Assignee: |
Unassigned |
Components: |
Image Pyramid |
Created: |
22/Aug/16 5:33 PM |
Environment: |
GeoServer 2.9.1, ImagePyramid plugin 2.9.1 |
Priority: |
Reporter: |
When rendering an ImagePyramid layer in certain views, parts of it appear to be shifted. Screenshot 1 has a Layer Group with ImagePyramid raster terrain shading on top of vector base map, which shows the relative shift. Screenshot 2 has just one component ImagePyramid layer showing that the issue is not related to Layer Group. I’ll try to produce a reasonably sized test case that can be shared in the coming days. |
This message was sent by Atlassian JIRA (v1000.253.3#100011-sha1:6da8fdb) |
