Nope, advanced projection handling should cut it properly, not throw an error. Unless you have it disabled, in that case there is no expected behavior, the code will just reproject point to point… from my tablet I cannot see the attachment, but want to make sure a regression is not put in code, throwing an exception that stops the rendering right away would be one unless endering is configured with a low error tolerance (hard to say what you mean exactly, not enough details)
Il 27 Ago 2016 14:52, “Torben Barsballe (JIRA)” <jira@anonymised.com> ha scritto:
Issue Type:
Bug
Assignee:
Unassigned
Created:
27/Aug/16 2:48 PM
Priority:
Medium
Reporter:
Torben Barsballe
This message was sent by Atlassian JIRA (v1000.285.1#100011-sha1:7e723f8)
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
