Torben Barsballe created an issue |
Issue Type: |
Assignee: |
Unassigned |
Components: |
JDBCStore |
Created: |
14/Sep/16 12:09 AM |
Priority: |
Reporter: |
With JDBCStore enabled, I create a new style. This style is correctly inserted into the JDBCStore. If I then try to assign the style to a layer, the style gets created within the old data directory. This should not happen! Note: The style (sld file) gets created in the data directory gets created as soon as I select it from the drop-down menu on the Publishing tab of the layer, presumably as part of the process that renders the style preview. |
This message was sent by Atlassian JIRA (v1000.319.1#100012-sha1:913341f) |
