Alessio Fabiani created an issue |
Backup and Restore may fail if java.io.tmpdir is not defined |
Issue Type: |
Assignee: |
Components: |
Backup and Restore, Community modules |
Created: |
14/Nov/16 12:25 PM |
Priority: |
Reporter: |
BackupUtils class needs to store temporary files in a temp folder. In order to do this it is now trying to do Resource root = Resources.fromPath(System.getProperty(“java.io.tmpdir”, “.”)); This causes an exception if the property “java.io.tmpdir” is null falling back to “.” java.lang.IllegalArgumentException: Contains invalid . path: The proposed solution would be to make use of the GeoServer data dir temp folder if the System variable is not available. GeoServer will WARNING the user about this since the GEOSERVER Data Dir temp folder may considerably increase in size. |
This message was sent by Atlassian JIRA (v1000.526.2#100018-sha1:d415428) |
