Since upgrading on 2.10.1 (previously on 2.9.1) a regression appeared :
- the first call on WMS GetCapabilities (without “If-None-Match” header) is ok
- the second call on WMS GetCapabilities (with “If-None-Match” header set to previous request response ETag) fail with a 404 error code.
All major browsers set “If-None-Match”, so every second call from a brower fails.
After some tests we concluded that GetCapabilities fails only when a “If-None-Match” header is set to a valid Etag returned by a previous call to geoserver GetCapabilities. It seems to be linked to the GetCapabilities cache.
Geoserver log this stack :
DEBUG [geoserver.ows] -
org.geoserver.ows.HttpErrorCodeException
at org.geoserver.config.CapabilitiesCacheHeadersCallback.operationDispatched(CapabilitiesCacheHeadersCallback.java:71)
at org.geoserver.ows.Dispatcher.fireOperationDispatchedCallback(Dispatcher.java:805)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:789)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:258)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:747)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:485)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:410)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:337)
at fr.sogelink.maplink.servlet.AbstractProxyServlet.redirectToGeoserveur(AbstractProxyServlet.java:202)
at fr.sogelink.maplink.servlet.AbstractProxyServlet.service(AbstractProxyServlet.java:169)
at fr.sogelink.maplink.filters.SimpleCorsFilter.doFilter(SimpleCorsFilter.java:65)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:218)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:958)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:452)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1087)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:637)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Thanks for your help ![]()
