[Geoserver-devel] [JIRA] (GEOS-8036) GetMap on images with ROI may fail on some edge cases
Andrea Aime [Administrator] created an issue
GeoServer / BugGEOS-8036
Issue Type:
BugBug
Assignee:
Components:
WMS
Created:
17/Mar/17 12:57 PM
Priority:
MediumMedium
Reporter:
Requirements for this to happen:
  • Source image with ROI
  • Reprojection with a small amount of rotation (not too little, not too much)
  • Request just outside of the image bounds
In this cases, with the right incantation above, the following might happen:
2017-03-02 17:00:06,047 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
	at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:354)
	at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:269)
	at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:139)
	at org.geoserver.wms.GetMap.executeInternal(GetMap.java:623)
	at org.geoserver.wms.GetMap.run(GetMap.java:279)
	at org.geoserver.wms.GetMap.run(GetMap.java:125)
	at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:320)
	at sun.reflect.GeneratedMethodAccessor315.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:302)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:190)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157)
	at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
	at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:62)
	at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:36)
	at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:80)
	at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
	at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208)
	at com.sun.proxy.$Proxy86.getMap(Unknown Source)
	at sun.reflect.GeneratedMethodAccessor314.invoke(Unknown Source)
	at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:857)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:268)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:144)
	at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:94)
	at org.geoserver.flow.ControlFlowCallback.doFilter(ControlFlowCallback.java:252)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:218)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:110)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:506)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:962)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:452)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1087)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:637)
	at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:318)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Thread.java:745)
Caused by: javax.media.jai.util.ImagingException: All factories fail for the operation "and"
	at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1687)
	at it.geosolutions.jaiext.ConcurrentOperationRegistry.invokeFactory(ConcurrentOperationRegistry.java:576)
	at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
	at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
	at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
	at javax.media.jai.RenderedOp.getSampleModel(RenderedOp.java:2233)
	at javax.media.jai.ROI.<init>(ROI.java:178)
	at javax.media.jai.ROI.createOpROI(ROI.java:592)
	at javax.media.jai.ROI.intersect(ROI.java:636)
	at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:1289)
	at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:352)
	... 126 more
Caused by: java.lang.reflect.InvocationTargetException
	at sun.reflect.GeneratedMethodAccessor180.invoke(Unknown Source)
	at javax.media.jai.FactoryCache.invoke(FactoryCache.java:122)
	at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
	... 136 more
Caused by: java.lang.IllegalArgumentException: The intersection of all the source bounds is empty.
	at javax.media.jai.PointOpImage.layoutHelper(PointOpImage.java:104)
	at javax.media.jai.PointOpImage.<init>(PointOpImage.java:369)
	at javax.media.jai.PointOpImage.<init>(PointOpImage.java:429)
	at com.sun.media.jai.opimage.AndOpImage.<init>(AndOpImage.java:78)
	at com.sun.media.jai.opimage.AndCRIF.create(AndCRIF.java:51)
	... 141 more
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.824.3#100035-sha1:74ec649)
Atlassian logo
