[Geoserver-devel] [JIRA] (GEOS-8073) Performing a WMTS GetCapabilities request with layer groups provokes a NPE
Nuno Oliveira created an issue
GeoServer / BugGEOS-8073
Issue Type:
BugBug
Assignee:
Unassigned
stacktrace.txt
Components:
GWC
Created:
05/Apr/17 12:04 PM
Priority:
MediumMedium
Reporter:
Nuno Oliveira
To reproduce this error just perform a WMTS get capabilities request where group layers are included, a NULL pointer exception will be throw (full stack trace attached):
java.lang.NullPointerException
	at java.util.HashMap.putMapEntries(HashMap.java:500)
	at java.util.HashMap.putAll(HashMap.java:784)
	at org.geowebcache.service.wmts.WMTSGetCapabilities.getLegendsInfo(WMTSGetCapabilities.java:516)
This happens because GeoServer doesn’t returns an empty map (default behavior of the overridden method) but instead NULL when no legends are available. This typically happens for layer groups which don’t have legends associated.
The line of code that does this:
https://github.com/geoserver/geoserver/blob/master/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java#L1277-L1280
GWC code can also be made more robust by ignoring NULL values.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.883.0#100040-sha1:084968a)
Atlassian logo
