[Geoserver-devel] [JIRA] (GEOS-8138) StyleFinder overwrites general MediaType mappings when a StyleHandler has a conflicting fileExtension
Matt Kruszewski created an issue
GeoServer / BugGEOS-8138
Issue Type:
BugBug
Assignee:
Unassigned
Created:
11/May/17 11:41 PM
Priority:
MediumMedium
Reporter:
Matt Kruszewski
If a custom StyleHandler uses a common file extension (e.g., “style.json”), the StyleFinder will overwrite the MediaType mapping for that extension with the mime type of the custom StyleHandler.
For example, when using the community MBStyleHandler (which uses the “json” file extension), the MediaTypes mapping from the “.json” extension to the “application/json” mime type is overwritten with “application/vnd.geoserver.mbstyle+json”.
As a result, any style-related request that uses the “.json” extension would return incorrectly (e.g., even /styles/someSLDStyle.json – or simply /styles.json).
Here is the relevant code in StyleFinder
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.929.2#100040-sha1:94c1764)
Atlassian logo
