Nuno Oliveira created an issue |
MongoDB integration with App-Schema nested mappings are not evealuted relatively |
Issue Type: |
Assignee: |
Components: |
Application schema |
Created: |
10/Nov/17 4:02 PM |
Priority: |
Reporter: |
When writing mappings for a MongoDB database integrated with App-Schema nested JSON paths should be evaluated relative to the parent … and this is not happening. JSON paths are being evaluated against the root JSON attribute. This means that everything works fine until we ave the same nested feature in a another path. The feature needs to be mapped twice since the full JSON path relative to the root JSON attribute needs to be provided. To reproduce this issue just create a mapping with a nested feature with more than a level, the full JSON path will need to be provided otherwise no content will be produced. |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100070-sha1:a53fe37) |
