[Geoserver-devel] [JIRA] (GEOS-8499) JNA lib in Status Monitor plugin is conlicting with Netcdf Out one
Gnafu created an issue
GeoServer / BugGEOS-8499
Issue Type:
BugBug
Affects Versions:
2.12.1
Assignee:
Unassigned
Components:
Community modules
Created:
20/Dec/17 11:36 AM
Environment:
Windows 8.1 64bit with Intel cpu
Priority:
MediumMedium
Reporter:
Gnafu
Adding both the NetCDF-Out plugin and the Status Monitoring community plugin to GeoServer will cause it to fail to start with a NoSuchMethodError.
The NetCDF-Out plugin is using an older version of the JNA library (4.1.0) while the Status Monitoring plugin need the 4.4.0 version, hence the error.
I can get GeoServer to startup by removing the jna-4.1.0.jar and keeping the jna-4.4.0.jar but I don’t know if this may cause any trouble to the NetCDF-Out plugin.
Here is the error:
20 dic 11:31:03 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'monitorRest': Unsatisfied dependency expressed through field 'systemInfoCollector'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'OSHISystemInfoCollector' defined in URL [jar:file:/G:/geoserver/geoserver-2.13-SNAPSHOT/webapps/geoserver/WEB-INF/lib/gs-status-monitoring-2.13-SNAPSHOT.jar!/org/geoserver/status/monitoring/collector/OSHISystemInfoCollector.class]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.geoserver.status.monitoring.collector.OSHISystemInfoCollector]: Constructor threw exception;
 nested exception is java.lang.NoSuchMethodError: com.sun.jna.platform.win32.WinNT$PSID.createFieldsOrder(Ljava/lang/String;)Ljava/util/List;
        at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:588)
        at org.springframework.beans.factory.annotation.InjectionMetadata.inject(InjectionMetadata.java:88)
        at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessPropertyValues(AutowiredAnnotationBeanPostProcessor.java:366)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1264)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:553)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:483)
        at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
        at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
        at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
        at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
        at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:761)
        at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:866)
        at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:542)
        at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:443)
        at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:325)
        at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
        at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:23)
I’m testing the 2.13 master build but I noticed the same libraries are in the 2.12 zip files as well
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100075-sha1:0ecdd78)
Atlassian logo
