[Geoserver-devel] [JIRA] (GEOS-8568) TextDecorationTest failure
Devon Tucker created an issue
GeoServer / BugGEOS-8568
Issue Type:
BugBug
Assignee:
Unassigned
Created:
01/Feb/18 6:46 PM
Priority:
MediumMedium
Reporter:
Devon Tucker
the TextDecorationTest fails, presumably anywhere behind GMT
org.junit.ComparisonFailure:
Expected :31.10.2008
Actual   :30.10.2008
 <Click to see difference>
	at org.junit.Assert.assertEquals(Assert.java:115)
	at org.junit.Assert.assertEquals(Assert.java:144)
	at org.geoserver.wms.decoration.TextDecorationTest.testExpandRequestVariable(TextDecorationTest.java:48)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.lang.reflect.Method.invoke(Method.java:497)
I took a brief look at it, but it’s not clear how to fix this test case. The date gets converted to local time (which I think is normal for java), but it’s not clear how to both format the output date into a consistent time zone, but I’m definitely not a Freemarker expert.
It’s not obvious what the intent of the test is, so I’m not sure what the fix is. If you just leave off all TZ info altogether then the test seems to work.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100078-sha1:b9ef3f0)
Atlassian logo
