Michael O’Meara created an issue |
Geoserver/GeoWebCache (Built In) GridSubset Extent Saves Incorrectly |
Issue Type: |
Affects Versions: |
2.11.1, 2.12.0 |
Assignee: |
Unassigned |
Created: |
15/Feb/18 10:34 PM |
Environment: |
Windows Server 2016 64 bit |
Priority: |
Reporter: |
Details from GIS Stack Exchange We have a very strange problem occurring with GeoServers Built in administration interface when dealing with GWC layer configuration. It seems when saving a layer cache configuration from the GeoServer admin, the resulting GWC layer configuration XML generates vastly different results (seemingly arbitrarily) under the <gridSubsets> tag. We’ve tested this on the two most recent versions of Geoserver (2.11.1 and 2.12.0) and both give the same results. All examples below use only the built in GWC grid sets (so, I don’t think it’s a grid set configuration problem). On first turning on GWC caching for a layer, the <gridSubsets> tag populates the default gridsets configured for GWC without any extent information. : <gridSubset> <gridSubset> <gridSubset> Does anyone have any idea what in the world could be going on here? Seen this behavior before? UPDATE Also confirmed this is still an issue in 2.12.1. Every time we save a layer change through the UI, it’s necessary to hunt down the GWC Layer XML file and confirm the extent didn’t go haywire. |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100079-sha1:96364fe) |
