The monitoring plugins does some post processing in a fixed size thread pool.
If the resources involved are secured, the following logs pop up in the logs:
Jussila Ville via aruba.it
9:08 AM (14 minutes ago)
to Andrea
2018-05-30 08:07:47,649 WARN [geoserver.monitor] - Post process task failed
org.springframework.security.authentication.InsufficientAuthenticationException: Cannot access johto as anonymous
at org.geoserver.security.SecureCatalogImpl.unauthorizedAccess(SecureCatalogImpl.java:933)
at org.geoserver.security.SecureCatalogImpl.buildWrapperPolicy(SecureCatalogImpl.java:910)
at org.geoserver.security.SecureCatalogImpl.buildWrapperPolicy(SecureCatalogImpl.java:792)
at org.geoserver.security.SecureCatalogImpl.checkAccess(SecureCatalogImpl.java:699)
at org.geoserver.security.SecureCatalogImpl.checkAccess(SecureCatalogImpl.java:683)
at org.geoserver.security.SecureCatalogImpl.getNamespaceByPrefix(SecureCatalogImpl.java:366)
at org.geoserver.catalog.impl.AbstractFilteredCatalog.getNamespaceByPrefix(AbstractFilteredCatalog.java:279)
at org.geoserver.catalog.impl.AbstractCatalogDecorator.getNamespaceByPrefix(AbstractCatalogDecorator.java:564)
at org.geoserver.monitor.LayerNameNormalizer.run(LayerNameNormalizer.java:53)
at org.geoserver.monitor.MonitorFilter$PostProcessTask.run(MonitorFilter.java:252)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
