[Geoserver-devel] [JIRA] (GEOS-8765) Undocumented GDAL 2.3.0 CSV output geometry column name change breaks WPSOgrTest
Ben Caradoc-Davies created an issue
GeoServer / BugGEOS-8765
Issue Type:
BugBug
Assignee:
Unassigned
feature.gml
Components:
WPS
Created:
31/May/18 3:43 AM
Environment:
debian sid gdal-bin 2.3.0+dfsg-1 amd64
Priority:
MediumMedium
Reporter:
Ben Caradoc-Davies
On debian sid gdal-bin 2.3.0+dfsg-1 amd64:
Tests run: 6, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 6.253 sec <<< FAILURE!
testOGRCSVOutputExecuteDocument(org.geoserver.wps.ogr.WPSOgrTest)  Time elapsed: 214 sec  <<< FAILURE!
java.lang.AssertionError
	at org.junit.Assert.fail(Assert.java:86)
	at org.junit.Assert.assertTrue(Assert.java:41)
	at org.junit.Assert.assertTrue(Assert.java:52)
	at org.geoserver.wps.ogr.WPSOgrTest.testOGRCSVOutputExecuteDocument(WPSOgrTest.java:169)
Failed tests:   testOGRCSVOutputExecuteDocument(org.geoserver.wps.ogr.WPSOgrTest)
Failure started after upgrade from GDAL 2.2.4 to GDAL 2.3.0 on Debian sid when processing a GML file with a geometry property called “geometry”:
$ ogr2ogr --version
GDAL 2.3.0, released 2018/05/04
$ ogr2ogr -f CSV -lco GEOMETRY=AS_WKT feature.csv feature.gml; grep STATE feature.csv
geometry,gml_id,STATE_NAME
Comparison with Ubuntu Bionic:
$ ogr2ogr --version
GDAL 2.2.3, released 2017/11/20
WKT,gml_id,STATE_NAME
GEOMETRY=AS_WKT is documented to output a geometry column WKT by default.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100086-sha1:9f755a9)
Atlassian logo
