I’m trying to use a JNDI Data Source as GWC Diskquota store.
GeoServer will create the tables in the database, but it will also report an error and disable the Disk Quota
Loading quota store failed, the disk quota subsystem is disabled, please re-configure: null
In the log I can find this:
18 set 12:52:26 INFO [geoserver.security] - Strong cryptography is available
18 set 12:52:57 INFO [jdbc.JDBCQuotaStore] - Closing up the JDBC quota store
18 set 12:52:57 INFO [config.GeoserverXMLResourceProvider] - Found configuration file in gwc
18 set 12:52:57 INFO [diskquota.ConfigLoader] - Quota config is: gwc/geowebcache-diskquota.xml
18 set 12:52:57 ERROR [geoserver.gwc] - Failed to load geowebcache-diskquota-jdbc.xml
org.geowebcache.config.ConfigurationException: No JDBC driver provided
at org.geowebcache.diskquota.jdbc.JDBCConfiguration.validateConfiguration(JDBCConfiguration.java:101)
at org.geowebcache.diskquota.jdbc.JDBCConfiguration.load(JDBCConfiguration.java:82)
at org.geoserver.gwc.JDBCConfigurationStorage.getJDBCDiskQuotaConfig(JDBCConfigurationStorage.java:84)
at org.geoserver.gwc.ConfigurableQuotaStoreProvider.loadJDBCQuotaStore(ConfigurableQuotaStoreProvider.java:147)
at org.geoserver.gwc.ConfigurableQuotaStoreProvider.getQuotaStoreByName(ConfigurableQuotaStoreProvider.java:136)
at org.geoserver.gwc.ConfigurableQuotaStoreProvider.reloadQuotaStore(ConfigurableQuotaStoreProvider.java:87)
at org.geoserver.gwc.GWC.saveDiskQuotaConfig(GWC.java:1263)
at org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage$1.onSubmit(DiskQuotaSettingsPage.java:143)
at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1309)
at org.apache.wicket.markup.html.form.Form.process(Form.java:976)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:797)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:708)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:216)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:241)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:234)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:895)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:159)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:157)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:174)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:967)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:901)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:872)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:73)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:37)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:317)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:70)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:51)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:112)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:158)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:141)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:347)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:263)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:90)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:79)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:215)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:110)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:499)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
at java.lang.Thread.run(Thread.java:748)
18 set 12:52:57 ERROR [geoserver.gwc] - Failed to get a quota store, the GeoWebCache disk quota subsystem will stop working now
java.lang.NullPointerException
at org.geowebcache.diskquota.jdbc.JDBCQuotaStoreFactory.getJDBCStore(JDBCQuotaStoreFactory.java:137)
at org.geowebcache.diskquota.jdbc.JDBCQuotaStoreFactory.getJDBCStore(JDBCQuotaStoreFactory.java:129)
at org.geoserver.gwc.ConfigurableQuotaStoreProvider.loadJDBCQuotaStore(ConfigurableQuotaStoreProvider.java:150)
18 set 12:52:57 INFO [diskquota.DiskQuotaMonitor] - Disk quota monitor shutting down...
18 set 12:52:57 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota usage monitor...
18 set 12:52:57 INFO [diskquota.QuotaUpdatesMonitor] - Shutting down quota usage monitor...
18 set 12:52:57 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota statistics gathering monitor...
18 set 12:52:57 INFO [diskquota.QueuedQuotaUpdatesConsumer] - Shutting down quota update background task due to InterruptedException
18 set 12:52:57 INFO [diskquota.QueuedUsageStatsConsumer] - Shutting down quota update background task due to interrupted exception
18 set 12:52:57 INFO [diskquota.DiskQuotaMonitor] - Shutting down clean up executor service...
18 set 12:52:57 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
18 set 12:52:57 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
18 set 12:52:57 INFO [diskquota.DiskQuotaMonitor] - 21 layers attached to global quota 500,0 MB
18 set 12:52:57 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 10 SECONDS
