To make life easier we made a C#-tool to copy workspaces in a single GeoServer instance.
When we change the element <name> in featuretype.xml from the original to the copy, then everything works fine.
When we don’t change the element <name>, then we get the following error :
Caused by: java.io.IOException: Schema ‘www.xxxxxxxxx.nl/0410181117:v_KDPGegevens_Geo’ does not exist.
at org.geotools.data.store.ContentDataStore.ensureEntry(ContentDataStore.java:535)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:333)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:594)
at org.geoserver.catalog.ResourcePool.getFeatureSource(ResourcePool.java:1266)
at org.geoserver.catalog.impl.FeatureTypeInfoImpl.getFeatureSource(FeatureTypeInfoImpl.java:123)
Looking at the code below from org.geoserver.catalog.ResourcePool * there’s something with *name , nativeName and nativeFeatureType , renamedFeatureType .
We’d like to know more about what happens here and if this explains the behavior we encounter…
// aliasing and type mapping
final String typeName = info.getNativeName();
final String alias = info.getName();
final SimpleFeatureType nativeFeatureType = dataStore.getSchema(typeName);
final SimpleFeatureType renamedFeatureType =
(SimpleFeatureType) getFeatureType(info, false);
if (!typeName.equals(alias)
|| DataUtilities.compare(nativeFeatureType, renamedFeatureType) != 0) {
// rename and retype as necessary
fs =
RetypingFeatureSource.getRetypingSource(
dataStore.getFeatureSource(typeName), renamedFeatureType);
} else {
// normal case
fs = dataStore.getFeatureSource(info.getQualifiedName());
