Richard Duivenvoorde created an issue |
RD (epsg:2892) to epsg:3857 (Google) reprojection cuts of map(tiles) |
Issue Type: |
Affects Versions: |
2.14.0 |
Assignee: |
Unassigned |
Attachments: |
cutoff.png |
Components: |
WMS |
Created: |
16/Nov/18 9:57 PM |
Priority: |
Reporter: |
Someone asked me to have a look at a Geoserver WMS which was showing strange ‘white stripes’. Looking into this it appeared he was using a Leaflet web app in epsg:3857, and serving a raster image which is actually a geotiff in epsg:28992 (later I found this behaviour in a totally unrelated ecw dataset). When zoomed in enough, it seems as Geoserver is ‘cutting off’ part of the map image on the right side of the image. In QGIS zoomed in at about > 1:5000 see But when you use a Leaflet application (which uses tiles) it is even more a problem because EVERY tile shows this cutoff aspect. To make this more easy to view, I created a little demo application: Note that when viewing this data in epsg:28992 (the native crs) all is fine! So it has something to do with (maybe?) a wrong clipping order or so? |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100095-sha1:c772008) |
