Arjan Odedra created an issue |
The host did not accept the connection within timeout of 30000 ms |
Issue Type: |
Affects Versions: |
2.11.2 |
Assignee: |
Unassigned |
Attachments: |
geoserver_error.txt |
Components: |
Mapfish print |
Created: |
30/Jan/19 12:44 PM |
Environment: |
OS: Linux(Ubutnu 18.04) |
Priority: |
Reporter: |
Print Module works well with URL which has a domain name attached to it (e.g www.example.com/geoserver/).but in my case, if I use some IP address (e.g 111.111.111.111/geoserver/) then it gives me an error Caused by: java.io.IOException: The host did not accept the connection within timeout of 30000 ms. i found it earlier with other geoserver too that print module didn’t work well with IP address. |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100098-sha1:2802614) |
