[Geoserver-devel] [JIRA] (GEOS-9292) Add support for GeoWebCache use by MapML service
Peter Rushforth created an issue
GeoServer / ImprovementGEOS-9292
Issue Type:
ImprovementImprovement
Affects Versions:
2.16-RC
Assignee:
Unassigned
Components:
MapML
Created:
22/Jul/19 10:16 PM
Priority:
MediumMedium
Reporter:
Peter Rushforth
  • When MapML panel says to “use tiles”, but aTCRS grid set doesn’t exist, use WMS GetMap for tile requests by default
  • For new layers, set the default grids to include MapML TCRS
  • Each layer can be configured to cache and serve tiles in GeoServer. While the MapML panel on the Layer page allows the admin to select “Use tiles”, as a checkbox, that doesn’t use the GWC tile cache if it is available.
  • Add support for WGS84 TCRS
  • Layer groups are very handy, and can be used with MapML, except that you can’t configure a layer group to use tile-based map requests. To do so would require adding a MapML panel to the publishing tab on the Layer Groups page.
  • Set min/max coordinate axis values on <input> included in extent
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100105-sha1:ccd8300)
Atlassian logo
