When trying to deploy I get various stack traces about classes not found. Seemingly all related to originating with the “org.reactivestreams.Publisher” class not being found.
2019-11-22 14:05:12,987 WARN [org.jboss.modules.define] (MSC service thread 1-1) Failed to define class org.springframework.http.server.reactive.AbstractListenerReadPublisher in Module "deployment.geoserver.war" from Service Module Loader: java.lang.NoClassDefFoundError: Failed to link org/springframework/http/server/reactive/AbstractListenerReadPublisher (Module "deployment.geoserver.war" from Service Module Loader): org/reactivestreams/Publisher
at java.base/java.lang.ClassLoader.defineClass1(Native Method)
at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1016)
at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1095)
at org.jboss.modules.ModuleClassLoader.doDefineOrLoadClass(ModuleClassLoader.java:424)
at org.jboss.modules.ModuleClassLoader.defineClass(ModuleClassLoader.java:555)
at org.jboss.modules.ModuleClassLoader.loadClassLocal(ModuleClassLoader.java:339)
at org.jboss.modules.ModuleClassLoader$1.loadClassLocal(ModuleClassLoader.java:126)
at org.jboss.modules.Module.loadModuleClass(Module.java:731)
at org.jboss.modules.ModuleClassLoader.findClass(ModuleClassLoader.java:247)
at org.jboss.modules.ConcurrentClassLoader.performLoadClassUnchecked(ConcurrentClassLoader.java:410)
at org.jboss.modules.ConcurrentClassLoader.performLoadClass(ConcurrentClassLoader.java:398)
at org.jboss.modules.ConcurrentClassLoader.loadClass(ConcurrentClassLoader.java:116)
at java.base/java.lang.Class.getDeclaringClass0(Native Method)
at java.base/java.lang.Class.getDeclaringClass(Class.java:1471)
at org.jboss.weld.core@anonymised.com//org.jboss.weld.util.reflection.Reflections.checkDeclaringClassLoadable(Reflections.java:427)
at org.jboss.weld.core@anonymised.com//org.jboss.weld.resources.ClassTransformer$TransformClassToBackedAnnotatedType.apply(ClassTransformer.java:83)
at org.jboss.weld.core@anonymised.com//org.jboss.weld.resources.ClassTransformer$TransformClassToBackedAnnotatedType.apply(ClassTransformer.java:79)
at org.jboss.weld.core@anonymised.com//org.jboss.weld.util.cache.ReentrantMapBackedComputingCache.lambda$null$0(ReentrantMapBackedComputingCache.java:55)
at org.jboss.weld.core@anonymised.com//org.jboss.weld.util.WeakLazyValueHolder$1.computeValue(WeakLazyValueHolder.java:35)
at org.jboss.weld.core@anonymised.com//org.jboss.weld.util.WeakLazyValueHolder.get(WeakLazyValueHolder.java:53)
at org.jboss.weld.core@anonymised.com//org.jboss.weld.util.cache.ReentrantMapBackedComputingCache.getValue(ReentrantMapBackedComputingCache.java:72)
at org.jboss.weld.core@anonymised.com//org.jboss.weld.util.cache.ReentrantMapBackedComputingCache.getCastValue(ReentrantMapBackedComputingCache.java:78)
at org.jboss.weld.core@anonymised.com//org.jboss.weld.resources.ClassTransformer.getBackedAnnotatedType(ClassTransformer.java:177)
at org.jboss.weld.core@anonymised.com//org.jboss.weld.resources.ClassTransformer.getBackedAnnotatedType(ClassTransformer.java:194)
at org.jboss.weld.core@anonymised.com//org.jboss.weld.resources.ClassTransformer.getEnhancedAnnotatedType(ClassTransformer.java:232)
at org.jboss.as.weld@anonymised.com//org.jboss.as.weld.injection.InjectionTargets.createInjectionTarget(InjectionTargets.java:64)
at org.jboss.as.weld@anonymised.com//org.jboss.as.weld.injection.WeldComponentService.start(WeldComponentService.java:121)
at org.jboss.msc@anonymised.com//org.jboss.msc.service.ServiceControllerImpl$StartTask.startService(ServiceControllerImpl.java:1739)
at org.jboss.msc@anonymised.com//org.jboss.msc.service.ServiceControllerImpl$StartTask.execute(ServiceControllerImpl.java:1701)
at org.jboss.msc@anonymised.com//org.jboss.msc.service.ServiceControllerImpl$ControllerTask.run(ServiceControllerImpl.java:1559)
at org.jboss.threads@anonymised.com//org.jboss.threads.ContextClassLoaderSavingRunnable.run(ContextClassLoaderSavingRunnable.java:35)
at org.jboss.threads@anonymised.com//org.jboss.threads.EnhancedQueueExecutor.safeRun(EnhancedQueueExecutor.java:1982)
at org.jboss.threads@anonymised.com//org.jboss.threads.EnhancedQueueExecutor$ThreadBody.doRunTask(EnhancedQueueExecutor.java:1486)
at org.jboss.threads@anonymised.com//org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1363)
at java.base/java.lang.Thread.run(Thread.java:834)
I do not get the error with Geoserver 2.15.3.
I originally hit the error with an older Wildfly, version 10, and I attempted to upgrade to version 18 to see if it would resolve the issue but it does not.
