[Geoserver-devel] [JIRA] (GEOS-9712) Errors in SQL DB Query on oracle
Pietro d’Orio created an issue
GeoServer / BugGEOS-9712
Issue Type:
BugBug
Affects Versions:
2.17.1
Assignee:
Unassigned
Components:
Oracle
Created:
03/Aug/20 1:26 PM
Priority:
MediumMedium
Reporter:
Pietro d’Orio
If an oracle view contains fields like “DATE” or “LEVEL” the SQL query performed on Oracle gives errors.
As result the WFS getfeature does not work.
GeoServer does call Oracle spatial with a query like this:
SELECT ID,LEVEL,GEOMETRY AS GEOMETRY FROM TABLE
That’s cause:
ORA-01788: CONNECT BY clause required in this query block
Queries with “DATE” fields cause.
: ORA-00936: missing expression
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100141-sha1:e1d49c9)
Atlassian logo
