Can I please ask you developers:
What would the best approach to fixing this be?
Upon loading the configuration, automatically remove a null style if the file (pophatch.xml) cannot be found/read - perhaps with a warning in a log file?
Give the user an explicit error message when rendering the UI and a null style is found?
Thanks
Peter
On Wed, 30 Sep 2020 at 20:57, Peter Smythe (JIRA) <jira@anonymised.com> wrote:
Issue Type:
Bug
Affects Versions:
2.17.2
Assignee:
Unassigned
Created:
30/Sep/20 8:54 PM
Environment:
Steps to reproduce:
Using the default install, rename pophatch.xml to pophatch.xml.break and reload the configuration or restart GeoServer
Click Tile Caching > Tile Layers - throws:
org.apache.wicket.WicketRuntimeException: Error attaching this container for rendering: [OddEvenItem [Component id = 8]]
at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1848)
Caused by: java.lang.NullPointerException
at org.geoserver.gwc.layer.StyleParameterFilter.setLayer(StyleParameterFilter.java:197)
at org.geoserver.gwc.layer.TileLayerInfoUtil.checkAutomaticStyles(TileLayerInfoUtil.java:162)
at org.geoserver.gwc.layer.TileLayerInfoUtil.checkAutomaticStyles(TileLayerInfoUtil.java:140)
at org.geoserver.gwc.layer.GeoServerTileLayer.lambda$getPublishedInfo$0(GeoServerTileLayer.java:401)
Alternatively, Data > Layers > topp:states > Publishing - throws:
org.apache.wicket.WicketRuntimeException: Error attaching this container for rendering: [Palette [Component id = extraStyles]]
at org.geoserver.wms.web.publish.StyleNameRenderer.getIdValue(StyleNameRenderer.java:20)
at org.apache.wicket.extensions.markup.html.form.palette.component.Recorder.initIds(Recorder.java:107)
Priority:
Medium
Reporter:
Peter Smythe
This is due to a layer (in this case topp:states) pointing to a style (pophatch) that no longer exists when the configuration is read from disk/catalog.
Unfortunately there are no logs that indicate which layer causes this problem and I had to view the Publishing page of each configured layer in order to determine which layer was at fault.
Saving the layer (on any tab other than Publishing) fixes the problem on disk, so the next time GeoServer reloads the problem is fixed.
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100147-sha1:3ed3880)
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
