Latest nightly for GeoServer 2.18 is not starting up when the GeoFence Server plugin is installed with the following exception:
2020-12-24 14:36:59.721:WARN:oejw.WebAppContext:main: Failed startup of context o.e.j.w.WebAppContext@anonymised.com{GeoServer,/geoserver,file:///home/alpa/Downloads/geoserver-2.18.1-bin/webapps/geoserver/,UNAVAILABLE}{/geoserver}
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geofenceEntityManagerFactory' defined in URL [jar:file:/home/alpa/Downloads/geoserver-2.18.1-bin/webapps/geoserver/WEB-INF/lib/geofence-persistence-3.4.6.jar!/applicationContext-geofenceDatasource.xml]: Invocation of init method failed; nested exception is javax.persistence.PersistenceException: [PersistenceUnit: geofence] Unable to build EntityManagerFactory
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1771)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:593)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:220)
at org.eclipse.jetty.start.Main.start(Main.java:490)
at org.eclipse.jetty.start.Main.main(Main.java:77)
Caused by:
java.lang.NoClassDefFoundError: net/sf/ehcache/CacheException
at java.base/java.lang.Class.getDeclaredConstructors0(Native Method)
at java.base/java.lang.Class.privateGetDeclaredConstructors(Class.java:3137)
at java.base/java.lang.Class.getConstructor0(Class.java:3342)
at java.base/java.lang.Class.newInstance(Class.java:556)
at org.hibernate.cache.impl.bridge.RegionFactoryCacheProviderBridge.<init>(RegionFactoryCacheProviderBridge.java:63)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
Caused by:
java.lang.ClassNotFoundException: net.sf.ehcache.CacheException
at java.base/java.net.URLClassLoader.findClass(URLClassLoader.java:471)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:589)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:555)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:490)
at org.hibernate.cfg.SettingsFactory.createRegionFactory(SettingsFactory.java:409)
at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:280)
at org.hibernate.cfg.Configuration.buildSettingsInternal(Configuration.java:2863)
at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2859)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1870)
at org.hibernate.ejb.Ejb3Configuration.buildEntityManagerFactory(Ejb3Configuration.java:906)
at org.springframework.orm.jpa.vendor.SpringHibernateEjbPersistenceProvider.createContainerEntityManagerFactory(SpringHibernateEjbPersistenceProvider.java:51)
at org.springframework.orm.jpa.LocalContainerEntityManagerFactoryBean.createNativeEntityManagerFactory(LocalContainerEntityManagerFactoryBean.java:343)
at org.springframework.orm.jpa.AbstractEntityManagerFactoryBean.afterPropertiesSet(AbstractEntityManagerFactoryBean.java:319)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1830)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1767)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:515)
at org.springframework.beans.factory.support.AbstractBeanFactory.lambda$doGetBean$0(AbstractBeanFactory.java:320)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:226)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:318)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:199)
at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1106)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:868)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:550)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:401)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:292)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:103)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:22)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:957)
at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:553)
at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:922)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:365)
at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1497)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1459)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:852)
at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:278)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:545)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:46)
at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:192)
at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:502)
at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:151)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:172)
at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:416)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:65)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:610)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:529)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:392)
at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:313)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:145)
at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:576)
at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:238)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:167)
at org.eclipse.jetty.server.Server.start(Server.java:418)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:119)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:113)
at org.eclipse.jetty.server.Server.doStart(Server.java:382)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1572)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1512)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1511)
2020-12-24 14:36:59.731:INFO:oejs.AbstractConnector:main: Started ServerConnector@anonymised.com{HTTP/1.1,[http/1.1]}{0.0.0.0:8080}
2020-12-24 14:36:59.732:INFO:oejs.Server:main: Started @3370ms
Full startup logs attached
