Style Params is ignored when rendering layergroup
2021-01-08 09:43:39,508 INFO [geoserver.wms] -
Request: getMap
Angle = 0.0
BaseUrl = http://tiles.postcodegenie.com/geoserver/
Bbox = SRSEnvelope[-392733.4513292357 : -392580.5772726653, 6571444.195733177 : 6571597.069789746]
BgColor = java.awt.Color[r=255,g=255,b=255]
Buffer = 0
CQLFilter = null
Crs = PROJCS[“WGS 84 / Pseudo-Mercator”,
GEOGCS[“WGS 84”,
DATUM[“World Geodetic System 1984”,
SPHEROID[“WGS 84”, 6378137.0, 298.257223563, AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”, 0.017453292519943295],
AXIS[“Geodetic latitude”, NORTH],
AXIS[“Geodetic longitude”, EAST],
AUTHORITY[“EPSG”,“4326”]],
PROJECTION[“Popular Visualisation Pseudo Mercator”, AUTHORITY[“EPSG”,“1024”]],
PARAMETER[“semi_minor”, 6378137.0],
PARAMETER[“latitude_of_origin”, 0.0],
PARAMETER[“central_meridian”, 0.0],
PARAMETER[“scale_factor”, 1.0],
PARAMETER[“false_easting”, 0.0],
PARAMETER[“false_northing”, 0.0],
UNIT[“m”, 1.0],
AXIS[“Easting”, EAST],
AXIS[“Northing”, NORTH],
AUTHORITY[“EPSG”,“3857”]]
Elevation =
Env = {}
Exceptions = SE_XML
FeatureId = null
FeatureVersion = null
Filter = null
Format = image/png
FormatOptions = {}
Get = true
Height = 128
Interpolations =
Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com, org.geoserver.wms.MapLayerInfo@anonymised.com, org.geoserver.wms.MapLayerInfo@anonymised.com420…, org.geoserver.wms.MapLayerInfo@anonymised.com, org.geoserver.wms.MapLayerInfo@anonymised.com, org.geoserver.wms.MapLayerInfo@anonymised.com, org.geoserver.wms.MapLayerInfo@anonymised.com, org.geoserver.wms.MapLayerInfo@anonymised.com, org.geoserver.wms.MapLayerInfo@anonymised.com, org.geoserver.wms.MapLayerInfo@anonymised.com6420…, org.geoserver.wms.MapLayerInfo@anonymised.com, org.geoserver.wms.MapLayerInfo@anonymised.com, org.geoserver.wms.MapLayerInfo@anonymised.com, org.geoserver.wms.MapLayerInfo@anonymised.com, org.geoserver.wms.MapLayerInfo@anonymised.com, org.geoserver.wms.MapLayerInfo@anonymised.com, org.geoserver.wms.MapLayerInfo@anonymised.com.6423…, org.geoserver.wms.MapLayerInfo@anonymised.com]
MaxFeatures = null
Palette = null
RawKvp =
{REQUEST=GetMap, FORMAT=image/png, SRS=EPSG:3857, BBOX=-392733.4513292357,6571444.195733177,-392580.5772726653,6571597.069789746, VERSION=1.3.0, UPPERCASE=false, STYLES=VML-fullcolor-Area,VML-backdrop-Line,VML-backdrop-RoadCLine,VML-backdrop-RailCLine,VML-backdrop-VectorMapPoint,VML-backdrop-Text, SERVICE=WMS, WIDTH=128, HEIGHT=128, TRANSPARENT=true, LAYERS=VectorMap:VectorMap}
RemoteOwsType = null
RemoteOwsURL = null
Request = GetMap
RequestCharset = UTF-8
ScaleMethod = null
Sld = null
SldBody = null
SldVersion = null
SortBy = null
SortByArrays = null
SRS = urn:ogc:def:crs:EPSG:3857
StartIndex = null
StyleBody = null
StyleFormat = sld
Styles = [StyleImpl[ name=VML-backdrop-Area], StyleImpl[ name=VML-backdrop-Line], StyleImpl[ name=VML-backdrop-RoadCLine], StyleImpl[ name=VML-backdrop-RailCLine], StyleImpl[ name=VML-backdrop-VectorMapPoint], StyleImpl[ name=VML-backdrop-Text], StyleImpl[ name=Default Styler], StyleImpl[ name=Default Styler], StyleImpl[ name=Default Styler], StyleImpl[ name=Default Styler], StyleImpl[ name=Default Styler], StyleImpl[ name=Default Styler], StyleImpl[ name=Default Styler], StyleImpl[ name=Default Styler], StyleImpl[ name=Default Styler], StyleImpl[ name=Default Styler], StyleImpl[ name=Default Styler], StyleImpl[ name=Default Styler]]
StyleUrl = null
StyleVersion = null
Tiled = false
TilesOrigin = null
Time =
Transparent = true
ValidateSchema = false
Version = 1.3.0
ViewParams = null
Width = 128
