Jan Boonen created an issue |
Issue Type: |
Bug |
Affects Versions: |
2.18.2 |
Assignee: |
Unassigned |
Components: |
REST |
Created: |
26/Feb/21 3:55 PM |
Environment: |
Ubuntu 18.04 |
Priority: |
Medium |
Reporter: |
After an upgrade from GeoServer 2.12 to 2.18 we have ran into some peculiar behaviour of the REST API. For historical reasons we use styles with colons in the name. When requesting these style via the endpoint {{ /rest/styles/ {name} .json }} we retrieve the information as expected (see example below). {{{ { “version”: “1.0.0” } , However, when we request the layer to which this style is connected via {{ /rest/layers/ {layerName} .json }} the name of the style has changed (see JSON response below). The part of the name before the first colon is duplicated! It seems to me that GeoServer treats this part as the workspace name, but the style is available in the global space. {{{ { “name”: “polygon”, “href”: “https://acc.geodan.nl/data/my/gws/rest/styles/polygon.json” } , { “name”: “GEOD8602XXXX:GEOD8602XXXX:test_bag_0b591144-b63a-44a0-bff2-e372a30a8be2:test”, “href”: “https://acc.geodan.nl/data/my/gws/rest/styles/GEOD8602XXXX%3Atest_bag_0b591144-b63a-44a0-bff2-e372a30a8be2%3Atest.json” } ] { “@class”: “featureType”, “name”: “GEOD8602XXXX:test_bag_0b591144-b63a-44a0-bff2-e372a30a8be2”, “href”: “https://acc.geodan.nl/data/my/gws/rest/workspaces/GEOD8602XXXX/datastores/GEOD8602XXXX/featuretypes/test_bag_0b591144-b63a-44a0-bff2-e372a30a8be2.json” } , { “logoWidth”: 0, “logoHeight”: 0 } , |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100154-sha1:2dd4382) |
