Message:
The following issue has been reopened.
Reopener: David Zwiers
Date: Mon, 9 Feb 2004 12:34 PM
On a server restart (with a new war file) you can directly access the styles page. Was thinking the UI should check for access on each page.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-46
Here is an overview of the issue:
Key: GEOS-46
Summary: UerContainer based login/logout needed
Type: Bug
Status: Reopened
Priority: Major
Original Estimate: 6 hours
Time Spent: Unknown
Remaining: 6 hours
Project: GeoServer
Fix Fors:
1.2-beta
Versions:
1.2-beta
Assignee: Richard Gould
Reporter: Jody Garnett
Created: Fri, 16 Jan 2004 5:27 PM
Updated: Mon, 9 Feb 2004 12:34 PM
Environment: config/struts layer
Description:
We need to figure out how to handle login/logout.
Struts In Action recomends making use of a UserContainer layer which acts as a strongly typed Session container.
Right now we are just recording things like the selected data store as their own entry in session.
This should change and we should use a UserContainer as managed by login/logout opperations. May need a separate security authorization mapping in web.xml - I am unclear on how the details work right now
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
