I’m looking at the build server and the situation is as per mail subject:
What does it mean? I’m guessing the setup is allowing only nodes at a certain
cost to be run, and none is available below that threshold?
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Yes, if there are jobs queued but no nodes online (or starting), it most likely means there are no available nodes that satisfy the constraints (i.e. cost).
(If all those jobs have only been waiting for ~15 mins then it might just be the Jenkins - EC2 plugin being a bit slow requesting a new node, but it looks like they were waiting for longer than that).
Torben
On Thu, Jul 11, 2019 at 2:40 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Geoserver-devel mailing list
