[Geoserver-devel] Key Auth Module and Geofence
Hello All,
I have been lately testing Key Auth module with external web service and using the User Group service from response body along with Geofence rules
the authentication seems to be working but when it passed to Geofence - Geofence can’t seem to find the associated roles.
So i decided to debug the source code
and found out that
org.geoserver.security.WebServiceBodyResponseUserGroupService from authkey module
is not implemented which is called by geofence.
@Override
public GeoServerUser getUserByUsername(String username) throws IOException {
return null;
if i modify the code to add this
@Override
String response = WebServiceAuthenticationKeyMapper.RECORDED_RESPONSE.get();
return loadUserByUsername(username, response);
It seems to work
But i did had to add the same Role that is recieved from web service response body
in the geoserver admin and assign that role to the group coming from webserivce.
was wondering why it was not implemented or am i doing something wrong?
Thanks
Murad
Hi Murad,
yep, it seems that the AuthKey method has just been stubbed and is missing a
real implementation.
Can you please create an issue, including the details of your setup?
Also, feel free to create a pull request with a proposed fix.
   Emanuele
Alle 07:16:10 di Friday 20 April 2018, Murad Jamal ha scritto:
Hello All,
Geofence can't seem to find the associated roles.
and found out that
module
@Override
IOException {
    return null;
@Override
IOException {
.get();
It seems to work
response body
webserivce.
Thanks
Murad
Emanuele Tajariol
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Emanuele Tajariol
Technical Lead
Via di Montramito 3/A
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo
è consentito esclusivamente al destinatario del messaggio, per le finalità
indicate nel messaggio stesso. Qualora riceviate questo messaggio senza
esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-
mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal
Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse,
costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely for the
attention and use of the named addressee(s) and may be confidential or
proprietary in nature or covered by the provisions of privacy act (Legislative
Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not
in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly
forbidden except previous formal approval of the named addressee(s). If you
are not the intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message that has
been received in error. The sender does not give any warranty or accept
liability as the content, accuracy or completeness of sent messages and
accepts no responsibility for changes made after they were sent or for other
risks which arise as a result of e-mail transmission, viruses, etc.
