On Sat, Jun 18, 2011 at 8:10 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
I am not sure this really warrants a separate branch of documentation...
seems like it could be one line of the build instructions. But it seems
there is pushback to removing the stable developer guide so I'll drop the
topic and hope that doc writers keep remember to keep the two in sync, a
step that i myself have already missed a few times.
Justin, have you tried git+cherry-pick for patch backports?
I've been using for a while, quite happy about it (a step above trying to
deal with backports in svn imho).
Rough steps to follow:
- checkout from svn with full tags and branches, with a shallow story
if you don't need it all,
something like:
git svn init -s --prefix=geoserver/ https://svn.codehaus.org/geoserver .
git svn fetch -r 16050:HEAD
- at this point git branch -r show show all tags and all branches that
have had at
least one commit between revision 16050 and HEAD (in this case,
trunk and 2.1.x)
If a new branch is added just run git svn fetch again (this time
without revision references)
- git svn checkout -b 2-1-x branches/2.1.x
- git svn checkout master
Now you commit something on master, get its id from git log, and then
git checkout 2-1-x
git cherry-pick <id>
(often this does not generate conflicts, sometimes it does and you
have to handle them)
<build>
git svn dcommit
This makes backporting really quick. The version of git I'm using can
only do single
cherry picks, but I hear the latest can cherry-pick a range of commits.
Hope this helps
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
