Andrea Aime asked:
Last time I checked application-schema datastore was read only?
Yes it is, but we should discuss this as part of the next steps strategy work.
This is sure interesting. Do you have a longer term plan about this?
I'll catch this one since I'm responsible for much of the strategy and associated funding that Ben and Rini are using to implement app-schema.
With respect to WFS-T support, it is on the list of "could-have" requirements. In Australia there is legislation that requires Industry to report some spatial information (mostly minerals exploration related) back to Government agencies. It has been suggested a number of times that this could be facilitated using WFS-T with GML application schemas like GeosciML. The trouble is, even if the feature was implemented, there are still cultural barriers that prevent this from happening. We won't be moving to add app-schema WFS-T support until we start to see the culture for the current publishing phase establishing. There are also a couple of other features higher up on the list of requests.
The immediate future (between now and June this year) is to complete app-schema read-only and have it deployed at a number of Australian geological surveys and research organisations (like my own) against production databases publishing GeosciML and similar GML application schemas. We're expecting this deployment will lead to a number of requests for improvement around configuration, performance and bugs we didn't catch in the tests.
We're currently funded until June 2011 (2 more years) and will continue to support this activity during that time. All improvements, fixes etc will be returned to the Geoserver community as per current activities (and we've been delighted at the response of the geoserver community to our contributions). We will also continue to watch the geoserver mailing lists and where we can (which I expect will be quite a lot) we'll look at issues coming in from the broader community as well.
Whilst we aren't currently active on the WFS-T app-schema support, if someone wanted to work on this then we would be happy to collaborate on it to aid the process. Its also entirely possible if things go well with our other priorities, we will get to it in the next couple of years just because it would nice to have the full read-write feature completed and we will eventually need it.
Rob
Dr Robert Woodcock
Auscope Grid - Director, Senior Research Scientist
CSIRO Exploration and Mining
ARRC (Australian Resources Research Centre)
26 Dick Perry Avenue, Kensington WA 6151, Australia
PO Box 1130, Bentley WA 6102, Australia
Ph: 08 6436.8780 | E: Robert.Woodcock@anonymised.com | W: www.csiro.au
-----Original Message-----
Sent: Friday, 20 March 2009 4:36 PM
To: Rob Atkinson
Cc: Geoserver-devel; Justin Deoliveira
Subject: Re: [Geoserver-devel] Layer names, resource aliases
about this?
And GeoServer must do WFS-T. What I really want is something that
allows me to rename attributes and map types on simple features
without:
1) getting a significant drop in performance
2) loosing the ability to write
This is perfectly reasonable set of objective criteria - its always
reasonable to put in optimisations for common special cases, but best
to do this against a design capable of handling all cases that will
matter.
In an ideal world, yes, but practice does not always agree with that.
The "general" case architecture usually has to do a lot more
work in order to deal with its generality, sometimes you can
just add a few checks in core places and you get the best
bang for the buck... and sometimes its clear that performance
was not considered during design and it's simply impossible,
or too hard, to retrofit it later.
If the application schema datastore can evolve to this point,
excellent, otherwise I'll roll out something simpler that handles
efficiently and effectively the common and simple case.
Its obviously expected that you will need to do this - the questions are:
1) can this be removed easily enough if a general solution emerges?
The current RW type renamer is just a wrapper around datastores
and feature collections. It could conceivably be evolved into
something that does simple renaming and type mapping keeping
a decent performance profile and without loosing RW capabilities.
As for easy of removal, it's currently hooked up into
the FeatureSource building chain by something like 15 lines of code
in a single method of ResourcePool.
Cannot get any easier to remove than this.
2) does rolling this out involve adding unsafe or unnecessarily
restrictive assumptions into parts of the code base?
Hmmm... I would not think so. If we ended up doing this the
harder to switch out part would be the mapping configuration.
But for sure I would make it so that it follows the current design
principle: _nothing_ outside of the classes that build up
the FeatureSource for the rest of GeoServer would know about it.
The rest would just play ball as usual, not knowing that the
FS it's playing against is actually a dynamic feature mapper.
And I want this kind of design for application schema as well.
Granted code modifications are needed to support complex
features, but I really do hope we won't have to make changes
in services to support application-schema mapping (besides
the WFS references to external, non GS generated schemas).
Andrea Aime
OpenGeo - http://opengeo.org
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Geoserver-devel mailing list
