I noticed two issues with specifying a layer name as part of a virtual
service that both seemed to be caused by line 63 in
org.geoserver.ows.OWSHandlerMapping not providing a workspace qualified
layer name:
if (catalog.getLayerByName(first) != null) {
Adding the workspace to the layer name seemed to fix both problems:
if (catalog.getLayerByName(wsName + ":" + first) != null) {
1. When JDBC Configuration is enabled, the request will return a 404
response if the layer name is used in more than one workspace. This is
because DefaultCatalogFacade returns the first layer if there is more than
one layer with the same name so this check still passes but
JDBCCatalogFacade returns null in that situation so it doesn't pass this
check.
2. If a layer name exists but is not in the specified workspace, the request
will be handled as if a layer was not provided in the request (e.g.,
"test/missing/wms" will be handled as "test/wms" if the layer "missing"
exists but not in the "test" workspace). This is because
LocalWorkspaceCallback uses the workspace qualified layer name when setting
the LocalPublished value and just ignores the layer name if it doesn't
exist, allowing the request to continue with only the LocalWorkspace set.
Steve Ikeoka
View this message in context: http://osgeo-org.1560.x6.nabble.com/Layer-Virtual-Service-Issues-tp5311443.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Hi Steve,
yep, I checked quickly and agree with your analysis.
I see you created the ticket, can you follow up with a pull request including a test?
On Wed, Mar 8, 2017 at 6:56 PM, sikeoka <steve.ikeoka@anonymised.com…2903…> wrote:
layer name:
if (catalog.getLayerByName(wsName + “:” + first) != null) {
JDBCCatalogFacade returns null in that situation so it doesn’t pass this
check.
“test/missing/wms” will be handled as “test/wms” if the layer “missing”
exists but not in the “test” workspace). This is because
the LocalPublished value and just ignores the layer name if it doesn’t
Steve Ikeoka
Announcing the Oxford Dictionaries API! The API offers world-renowned
dictionary content that is easy and intuitive to access. Sign up for an
account today to start using our lexical data to power your apps and
projects. Get started today and enter our developer competition.
http://sdm.link/oxford
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
