I am getting an exception at geoserver startup leading to a wipe out of all the layers. The exception is:
java.lang.IllegalArgumentException: argument type mismatch
at org.geoserver.catalog.impl.CatalogImpl.resolveCollections(CatalogImpl.java:1548)
This is because of the mismatch in LayerInfo.getMetadata():Map<String, Serializable> and LayerInfoImpl.getMetadata():MetadataMap
So CatalogImpl.resolveCollections tries to assign an empty HashMap instead of a MetadataMap.
Ok to change the declaration of LayerInfo.getMetadata and commit?
(and know why this didn't come up before?)
Gabriel.
Gabriel Roldan
OpenGeo - http://opengeo.org
Oops, this has to do with the commits for GEOS-3313. I ran into the same issue with LayerGroupInfo, missed it for LayerInfo though. But yeah, changing the declaration will do the trick. Fix commited.
-Justin
Gabriel Roldan wrote:
Gabriel.
Justin Deoliveira
