Hi Devs,
I'm unable to run the acme-ldap-1.0.jar test ldap server from:
https://docs.geoserver.org/latest/en/user/security/tutorials/ldap/index.html
It seems trivial to fix (see below), but the jar has only class files in it.
On Debian BookWorm,
$ java -version
openjdk version "11.0.14.1" 2022-02-08
OpenJDK Runtime Environment (build 11.0.14.1+1-post-Debian-1)
OpenJDK 64-Bit Server VM (build 11.0.14.1+1-post-Debian-1, mixed mode, sharing)
Where does the code live?
Regards and thanks for any pointers
Richard Duivenvoorde
$ java -jar acme-ldap-1.0.jar
[2022-52-20T10:52:42.042+0200] INFO [org.apache.directory.server.core.DefaultDirectoryService] - ApacheDS shutdown hook has been registered with the runtime.
[2022-52-20T10:52:42.042+0200] DEBUG [org.apache.directory.server.core.DefaultDirectoryService] - ---> Initializing the DefaultDirectoryService
Exception in thread "main" java.lang.ExceptionInInitializerError
at org.apache.directory.server.core.partition.ldif.LdifPartition.getOSFileName(LdifPartition.java:630)
at org.apache.directory.server.core.partition.ldif.LdifPartition.getFileName(LdifPartition.java:621)
at org.apache.directory.server.core.partition.ldif.LdifPartition.doInit(LdifPartition.java:187)
at org.apache.directory.server.core.partition.AbstractPartition.initialize(AbstractPartition.java:65)
at org.apache.directory.server.core.schema.SchemaPartition.doInit(SchemaPartition.java:229)
at org.apache.directory.server.core.DefaultDirectoryService.initialize(DefaultDirectoryService.java:1426)
at org.apache.directory.server.core.DefaultDirectoryService.startup(DefaultDirectoryService.java:907)
at org.acme.Ldap.initDirectoryService(Ldap.java:192)
at org.acme.Ldap.<init>(Ldap.java:272)
at org.acme.Ldap.main(Ldap.java:306)
Caused by: java.lang.NumberFormatException: multiple points
at java.base/jdk.internal.math.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1914)
at java.base/jdk.internal.math.FloatingDecimal.parseFloat(FloatingDecimal.java:122)
at java.base/java.lang.Float.parseFloat(Float.java:455)
at org.apache.directory.shared.ldap.util.SystemUtils.getJavaVersionAsFloat(SystemUtils.java:1336)
at org.apache.directory.shared.ldap.util.SystemUtils.<clinit>(SystemUtils.java:944)
... 11 more
On 20-05-2022 11:01, Richard Duivenvoorde wrote:
Hi Devs,
On Debian BookWorm,
$ java -version
DuckDuck suggests it lives (lived) at https://github.com/bhoefling-c2c/acme-ldap but that no longer exists
You may be able to contact Björn Höfling (https://github.com/bhoefling-c2c) or Camptocamp directly.
It seems to be a slightly customized version of Apache DS which lives at https://directory.apache.org/apacheds/
it probably has problems with the Java version, you could try running with java 7 or 8
Mark
(attachments)
Looks like there is a copy buried inside the GeoServer docs too:
https://github.com/geoserver/geoserver/tree/main/doc/en/user/source/security/tutorials/ldap/acme-ldap
Does not build for me though, there are issues in the pom file (I see recent activity related to the
Log4J upgrade).
Cheres
(attachments)
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
