So, yes this was caused by the default geometry support commit, my apologies
The interesting thing is that the default geometry tests are not mean to run as
online tests, so I was a bit surprised to see them running …
I checked why they were running as online tests, since they were not configured
that way, and it turns out that apparently having Geometry in the test name makes
you suitable to run as an online App-Schema test.
I could no find out why this is happening, I generated the effective pom and there
was nothing supporting this, so I’m completely clueless … anyone can shine a
light on this ?
That say, I make a PR [1] that explicitly excludes the DefaultGeometryeTest from the
online test build …
Nuno Oliveira
[1] https://github.com/geoserver/geoserver/pull/2816
On 03/27/2018 06:26 PM, Nuno Oliveira wrote:
Looking into it …
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On 03/27/2018 06:13 PM, Torben Barsballe wrote:
Hello all,
Build pipeline has cleared up, nightlies should be up-to-date again.
The app-schema test still hangs if I re-run it, so this wasn’t a fluke. Specifically, it hangs when executing org.geoserver.test.DefaultIdTest.
The only app-schema change in the timeframe of this failure is from https://github.com/geoserver/geoserver/pull/2804
Nuno - any comments here? The offline tests all seem to be working fine, the only failures are in the online tests.
Torben
On Mon, Mar 26, 2018 at 11:55 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
The last job for geoserver-master-app-schema-online hung for 4 days (which has backed up build.geoserver.org). I have canceled it.
The server is a bit backed up right now, so changes / nightly builds may take a little while to show up. I’m clearing out duplicates an will monitor the situation.
It may be worthwhile to consider something like the Build Timeout plugin to handle this sort of thing in the future, since this seems to happen occasionally.
If anyone has an idea as to what might have caused those tests to hang up, that would be good to know. Based on the initial logging, the remote DB does appear to be up and running.
Torben
Nuno Oliveira
@nmcoliveira
Software Engineer
