Thanks for making DMG Justin. Were you able to try it?
The application window starts up for me, selected “Start” from the menu instantly pops open http://locahost:8080/geoserver/web window with a “HTTP ERROR: 404”.
I am going to guess this is a java 1.6 vs 1.7 trouble?
Checking Contents/Info.plist shows:
JVMVersion
1.5*
Changing this to 1.7* will not start, not sure what else to try.
Everything is up on source forge, website page(s) created etc… I can start writing blog post tomorrow. A bit sad that so much is broken … but it is a beta.
On Thu, Jul 24, 2014 at 9:10 AM, Jody Garnett <jody.garnett@anonymised.com>
The application window starts up for me, selected "Start" from the menu
"HTTP ERROR: 404".
<key>JVMVersion</key>
<string>1.5*</string>
Jody, a bit confused by the title, which states 2.5... you're talking about
2.6 here or... what?
Justin produced the DMG, not sure if he lightly tapped the mac build box, or downloaded the pieces and built locally. I will check back tomorrow and build you a DMG if needed.
JVMVersion
1.5*
Jody, a bit confused by the title, which states 2.5… you’re talking about 2.6 here or… what?
As mentioned on the ticket I won’t be able to get to trying to fix this right away. So I am thinking we should probably take down the download if it’s up and we’ll have to wait for the osx installer for the official 2.6 release.
JVMVersion
1.5*
