From the build server:
[ERROR] BUILD FAILURE
[INFO] Compilation failure
/var/lib/hudson/jobs/geoserver-master/workspace/src/community/jdbcconfig/src/main/java/org/geoserver/jdbcconfig/catalog/JDBCCatalogFacade.java:[52,7] org.geoserver.jdbcconfig.catalog.JDBCCatalogFacade is not abstract and does not override abstract method <T>list(java.lang.Class<T>,org.opengis.filter.Filter,java.lang.Integer,java.lang.Integer,org.opengis.filter.sort.SortBy...) in org.geoserver.catalog.CatalogFacade
Can anybody fix it? Or should we push the jdbcconfig module out of the nightly builds?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Kevin is currently working on a patch for this. I’ll check in with him and if its not close to being committable i will disable it from the nighties for now.
On Thu, Jun 20, 2013 at 8:17 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
On Thu, Jun 20, 2013 at 7:24 PM, Justin Deoliveira <jdeolive@anonymised.com>wrote:
Kevin is currently working on a patch for this. I'll check in with him and
Sounds great, thank you
Ing. Andrea Aime
@geowolf
Technical Lead
