What maven version is everyone using?
I have installed the latest (2.0.9 at this time) and for some reason
geoserver does not build with it.
I had to downgrade to a previous version in order to complete the
compile. Here is the error snippet:
urls[29] = file:/home/apetkov/.m2/repository/bsh/bsh/1.3.0/bsh-1.3.0.jar
[FATAL ERROR] Container realm = plexus.core
urls[0] = file:/opt/maven/lib/maven-2.0.9-uber.jar
[ERROR] FATAL ERROR
[INFO] org.apache.maven.tools.plugin.scanner.MojoScanner.setActiveExtractors(Ljava/util/Set;)V
[INFO] Trace
java.lang.NoSuchMethodError:
at org.apache.maven.plugin.plugin.AbstractGeneratorMojo.execute(AbstractGeneratorMojo.java:116)
at org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:451)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:558)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalWithLifecycle(DefaultLifecycleExecutor.java:499)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor.java:478)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultLifecycleExecutor.java:330)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleExecutor.java:291)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java:142)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:336)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:129)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:287)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
[INFO] Total time: 48 seconds
[INFO] Finished at: Tue May 06 08:31:00 MDT 2008
[INFO] Final Memory: 16M/29M
Alex
I use maven 2.0.6 without any problems. Our build server uses 2.0.8.
-Justin
[ERROR] FATAL ERROR
[INFO] Trace
Alex
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference Don't miss this year's exciting event. There's still time to save $100. Use priority code J8TL2D2. http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Geoserver-devel mailing list
!DSPAM:4007,48206c77206722458217002!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Hmmm... given that gt2 is going to switch to 2.0.9 next week,
and given that I would not like very much to have a different maven
for gt2 and gs, I'm going to have a look into this one.
