Hi all, especially the old-timers
In the developer documentation https://docs.geoserver.org/latest/en/developer/programming-guide/web-ui/overview.html, at the bottom of the page it says:
A
ComponentInfoinstance contains meta information about the component being plugged in such as its title and description, as well as the class which implements the component.
Each subclass of
ComponentInforepresents a specific extension point. For instance the classorg.geoserver.web.MenuPageInforepresents the extension point for “main” pages, ie pages that are linked to from the main menu of the application.
This hyperlink https://docs.geoserver.org/latest/en/developer/programming-guide/extension-points/index.html#extension-points is basically a blank page.
According to https://github.com/geoserver/geoserver/commits/main/doc/en/developer/source/programming-guide/extension-points it has been like this since 2011. Is that when the code/docs were migrated from SVN to Git?
Did this page exist before then, does anyone have a copy of the page so that I can import it, or can anyone provide a brief explanation of what an extension point is?
Thanks
Peter
