[Geoserver-devel] mkdocs preflight rst fixes, call out for any pending rst documentation changes
I have assembled a PR here of preflight changes to rst content: https://github.com/geoserver/geoserver/pull/7429
(Just hunting down some broken relative links and PR is ready to review).
I would live to convert next Wednesday 21 February, after (after the stable release has gone out).
Thanks
Jody Garnett
Hi Jody,
I had a quick look, but the PR is still marked as Draft. Will you let us know when it’s “ready for review”?
Jody Garnett
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Thanks, I took some time out to document the translate script and teach it to generate the nav tree from toctree directives: https://jodygarnett.github.io/translate/
I would double check the translation is smooth, and take this out of draft.
(attachments)
Jody Garnett
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Okay docs are updated: https://jodygarnett.github.io/geoserver/
Taking the RST changes PR out of draft: https://github.com/geoserver/geoserver/pull/7429
The above PR is just the changes to RST files (and should be suitable for backport).
(attachments)
Jody Garnett
Jody Garnett
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Hello Jody,
On firefox and chrome, the top menu is stopped after REST.
On the home page, I find it strange to have the list of the main pages and then below again a table with the same pages.
Alexandre
(attachments)
Jody Garnett
Jody Garnett
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Alexandre Gacon
Hi Jody,
I believe some way to assign section to a volunteer is needed, or you’ll get some sections checked twice and others never
(attachments)
Jody Garnett
Jody Garnett
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Maybe we can set up a spreadsheet?
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Here is a google spreadsheet which people can contribute to (just ask for access to edit). That way we can avoid multiple people checking the same page (and we can also know when we are done).
https://docs.google.com/spreadsheets/d/1HMqUpTirEwwSQfeNYikPjU0aFMl0-W4Xj44cg8V_VJA/edit?usp=sharing
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
