[Geoserver-devel] multiple coverages in a grid coverage reader
Hello Mailing List,
I am writing a geopkg coverage reader. A geopkg can have many coverages, each of which can have their own envelope, CRS, resolutions, ...
Currently the API works as follows.
- The GridFormatFactorySpi Service returns a AbstractGridFormat (not the GridFormat interface but an abstract class)
- The AbstractGridFormat class returns an AbstractGridCoverage2DReader (not the GridCoverage2DReader interface but an abstract class).
AbstractGridCoverage2DReader contains lots of implementation, so we have a bit of a mixture between API and implementation here.
The AbstractGridCoverage2DReader was written we the assumption of a single coverage per data source.
Recently, the GridCoverage2DReader was changed to allow multiple coverages, now being used by netcdf. However netcdf still must derive from the AbstractGridCoverage2DReader for the reasons above, however overrides the necessary methods to allow multiple coverages. This seems to work fine for netcdf, but there are issues for geopkg. AbstractGridCoverage2DReader uses in many methods variables called 'crs', 'originalEnvelope', 'highestResolution', ... all under the assumption there is only one of those.
My proposal to solve this problem - without a change in the API - is to replace all occurrences of these variables in AbstractGridCoverage2DReader to a call to functions. For example an occurence of 'crs' in the code would be replaced by a call to 'getCoordinateReferenceSystem(coverageName)'. All methods dependant on these functions would take a 'coverageName' as argument, but a second function without that argument would remain for backward compatibility, using the 'coverageName' variable as argument. All the variables would remain, the default implementation would be to return those variables. This way geopkg can simply override the functions and ignore the variables. But there would be perfect backward compatibility towards the subclasses that use the variables.
This would work by itself, but could also be a first step towards refactoring the API. Additionally, but not necessarily, we could split the AbstractGridCoverage2DReader into two classes;
- AbstractGridCoverage2DReader would have an abstract getCoordinateReferenceSystem(coverageName) method. The geopkg reader would derive directly from this.
- A subclass, for example SingleGridCoverage2DReader would make the default implementations using the variables under the assumption that there is only one coverage. All the existing single-coverage readers would then derive from SingleGridCoverage2DReader.
The benefit would be that we wouldn't have all the variables in a subclass that doesn't use them (it's cleaner). Finally, the API could optionally also be changed to use interfaces instead of abstract classes.
Regards
Niels
On Tue, Jan 14, 2014 at 2:33 PM, Niels Charlier <niels@anonymised.com> wrote:
Hello Mailing List,
Well.. no, the methods in question can be overridden, this means you
can have them work with multiple coverages:
    @Override
    public GeneralEnvelope getOriginalEnvelope(String coverageName) {
        if(!checkName(coverageName)){
            throw new IllegalArgumentException("The specified coverageName
" + coverageName + "is not supported");
        return getOriginalEnvelope();
* Retrieves the {@link GeneralEnvelope} for this
* {@link AbstractGridCoverage2DReader}.
* @return the {@link GeneralEnvelope} for this
public GeneralEnvelope getOriginalEnvelope() {
return new GeneralEnvelope(originalEnvelope);
What's stopping you from overriding getOriginalEnvelope(String
coverageName)?
The reason why getOriginalEnvelope() (without the coverage name) was
kept was to avoid breaking all of the existing client code just for the sake
of NetCDF.
If your implemetation does not have a shared original envelope you just
throw an unsupported operation exception for the moment, and find out
what works and what does not on top of it (there might still be code around
that does not know about coverage names).
But... isn't this what we have now?
    @Override
    public CoordinateReferenceSystem getCoordinateReferenceSystem(String
coverageName) {
        // Default implementation for backwards compatibility
        return getCoordinateReferenceSystem();
    @Override
    public CoordinateReferenceSystem getCoordinateReferenceSystem() {
        return getCrs();
This approach seems sensible.
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Mon, Jan 27, 2014 at 5:51 PM, Andrea Aime
    @Override
coverageName) {
    @Override
        return getCrs();
Ah ok, got it, you want to replace the direct field access with function
calls.
Yes, it works... I'm just worried over time we'll have subclass code try to
access
fields directly.
Maybe make the fields private to eliminate the temptation fully?
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
On 27/01/14 17:51, Andrea Aime wrote:
What's stopping you from overriding getOriginalEnvelope(String coverageName)?
of NetCDF.
No, variables like 'crs' and 'originalEnvelope' are being used by the code. If they are left empty, you will get exceptions thrown when you try to load the data in geoserver.
My suggestion is to replace the calls to these variables in the code by calls to the functions, which are indeed already in place.
Regards
Niels
Ciao Niels,
I had a cursory lokk at the changes and they seem to bring clarity as
well as doing some cleanup.
I will ask daniele tomorrow to review and test the pull on all the the
raster plugins.
Simone Giannecchini
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
On Mon, Jan 27, 2014 at 6:16 PM, Niels Charlier <niels@anonymised.com> wrote:
coverageName)?
the sake
of NetCDF.
around
Regards
Niels
CenturyLink Cloud: The Leader in Enterprise Cloud Services.
Learn Why More Businesses Are Choosing CenturyLink Cloud For
Critical Workloads, Development Environments & Everything In Between.
Get a Quote or Start a Free Trial Today.
http://pubads.g.doubleclick.net/gampad/clk?id=119420431&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Hi Niels,
I have reviewed the Pull request and it seems good to me.
I’ll do some testing with that code as soon as I can and I’ll merge it when done.
Thanks for your contribution.
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
On Tue, Jan 28, 2014 at 8:33 PM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Niels,
raster plugins.
Simone Giannecchini
more information.
@simogeo
Founder/Director
What’s stopping you from overriding getOriginalEnvelope(String
coverageName)?
the sake
of NetCDF.
around
But… isn’t this what we have now?
No, variables like ‘crs’ and ‘originalEnvelope’ are being used by the
Regards
Niels
Hi Niels,
I did some tests in geoserver with the latest code and it seems good so I have merged your updates.
Daniele
On Wed, Jan 29, 2014 at 3:21 PM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hi Niels,
Daniele
Ciao Niels,
raster plugins.
Simone Giannecchini
more information.
@simogeo
Founder/Director
coverageName)?
the sake
of NetCDF.
around
Regards
Niels
